- 7:30 AM
- Sep 15, 2009
- State of insanity
Why not just get another Milodon pickup ?
i've done #2 on a 3/8" pick-up. fairly easy. i bet some dummy used a tapered tap and ran it too deep.First you should mock up everything to make sure you have the pickup to oil pan clearance you want knowing you’ll be going a little deeper.
Your pictures from both of your threads show that the machine shop ran the 1/2” NPT tap deep into the block. You can:
1) drill, ream, remove the first 2 or 3 threads from the block to allow the new pickup to tighten up in the bottom of the taper, or
2) get a NPS die and extend the PU threads, or
3) Get a NPT die and extend the PU threads.
Any of these will work. If the PU is to far from the oil pan, you’ll need to go to plan B
When you say it like that, it sounds kinda obviousWhy not just get another Milodon pickup ?
