- 7:50 PM
- May 31, 2015
- paying it forwards
hi from western ny.
im trying to resurrect this 440 4 door sedan ive just rescued from a field,the paperwork shows last time onroad as 1982...needing a bit of advice.
it appears to be a 1965 383 motor and maybe? a 65 trans as well.
the block id is
A 383 with a maltese cross
12 142
R
casting number is 2468130-4
i cant find any info on the trans,so ive included pics of the cables? going into trans- front and rear.
the rearend has been swapped with something thats too narrow,but maybe same vintage.
looks to be an A-body? but its got nuts on the ends of axles.
the guy i got it from got it running once,at which point it drove itself backwards into his porch.
im gonna have some fun with the push button shifter im guessing.
ive already noticed neutral seems to be stuck inwards.
soo,im going for a daily driver beater,hence the handle and looking for advice.
what would you do with this car cheaply,to get some bang back in it.
seeing as this is a b body,will a 70 coronet 8-3/4 fit in there correctly?
can i use the leaf springs too?
will i be able to cam this up,and what convertor should i use w the trans?
if its a 65,can i even get a good vertor for it?
i have an offy high rise intake and some edelbrocks and a couple of the thermoquads.
worth using?
thanks in advance,for any help.
i do have a shot at a 75 cordoba/charger complete for parts,i was thinking the disc brakes and ? whatever else could be reused if those parts will interchange?
i saw someones reply where they said they used volare but not how they did it.
please see my wtb parts trim thread as well,if you have anything for this car
http://www.forbbodiesonly.com/mopar...B-Exterior-Trim-for-1962-dodge-dart-440-sedan
the block id is
12 142
R
worth using?
at the end of the pics im including a shot of the rims i thought would look good on it,but the bolt pattern seems to be chevy.
anyone know what brand the mags are?
i looked on the back and didnt see any marks??
