My 76 Charger Pics
ezcook
10:32 PM
el sobrante, ca
Here they are in all its glory.
Now I got her fired up for a sec then nothing...even a little starter fluid does nothing, damn lean burn system...if any body knows how to upgrade the system ect that will still pass Cali smog any info would be great, don't think the odds of finding a computer for her if it went out are good lol.
By pass it by replacing it
Install a mopar performance electronic ignition system and you are done. It comes as a kit and is basically an ECU (brain box), big block electronic distributor (with vacuum advance), and associated wiring. You will need to remove/replace your fix timing lean burn distributor and wire it in along with your new ECU. Wiring diagrams should be provided in the kit. The previous owner did it with some OEM parts he had laying around on mine. I’m working on mine now and hope to be running soon.
Nice looking car you have there.
As far as emissions go… if set up and tuned right it should have better emissions than a goofed up shake and bake system (read lean burn). You may need to plug your vacuum advance and minimize your initial timing advance to pass.
elect_ign_wir.jpgYou do not need to replace your carb. Here is a pic of the wiring diagram I found.
