Badvert65
- 10:40 AM
- Oct 11, 2013
- Brightwood, Virginia
If it weren’t for bad luck…
Finally getting the Belvedere back together after the brake melt down. Hoping for test and tune this Thursday at the local track. Car has been up on jacks for nearly two weeks. New leaf springs, shocks, all poly bushings, 3.55 sure grip added as well as everything new in the rear brakes. Car was running great when I started this project. OK, so I finally get it back on all four wheels, ready for a test drive. That’s when things went south…. I start the engine and it is running awful, bucking, shaking, and spitting oil out the valve cover breather. Oil smells like gas, great. So, I jack up the car, replace the fuel pump, drain 10 quarts of gas/oil mix and replace with fresh oil. OK, lower the jack and….frikkin car is in neutral and rolls down the driveway. Luckily (?), it gets stopped by some bushes, no damage to the car. But it aint over yet….I start up the car, drive past the bush, onto the street. I put it into reverse and I am rewarded with an unnerving screeching noise. Frikkin gear set I just put in is messed up. Of course it is. Time to give up for now as I just can’t take any more of this.
Good times...
Good times...
