N96 question
dcmason69
2:22 PM
Seward Nebraska
Adding a N96 hood to 69 Coronet with power disc. do I need to be concerned with
Ramcharger duct clearance, or is that only on cars with HEmi engines that there was
a special shape to the left hand duct ? I have the regular 440 ramcharger duct work now.
thank you dcmason69
As far as I know the Hemi with the booster is tho only one that needs the different duct.
Yes
Just need to be sure before l proceed, actually what I am doing is going from manual to power brakes
Thanks for the info
Yes
Thanks for the info
Who’s power brake system?
Factory parts, or that GM based aftermarket mess?
Using factory booster rebuilt by power booster xchange but using a MBM replacement cyl. 1.125 bore I believe it will work ok.
Any opinions welcome
True that! If it has this abortion on it it won't even clear a hood, let alone the air box.
my '69 r/t has the factory n96 with a midland-ross booster and everything fits good.
Ok good info
I am using a series 1 bendix so I believe I will be ok also:
Not sure what a midland looks like
I guess mine is considered trapezoid
Appreciate the reply
