onephat66
Ok, I took the car out last night for a drive. Passenger side fender mounted turn signal quit working, so I'm guessing it's the bulb. After fighting with the connectors I was able to remove both turn signals and pulled the bulbs out. Those dang bulbs are so frickin small I can't tell if they're burnt out or not, and can barely see the number on them!!! Of course, no one stocks those damn things!!!! I also discovered I think it's time to replace the headlight switch as the lights flickered a couple times and when I twist the knob I have to be careful how I twist it so the dash lights light up. I may replace the dimmer switch too for good measure, since they're cheap. I'm also going to freshen up my arm rests and install my new arm rest bases I've had for years as well. Still haven't figured out the fuel issue I mentioned above, but it didn't act up last night, so that was good. I'm sure it'll be a matter of time though if I don't figure it out.
