Need 66 charger 318 timing cover (Passenger side timing marks)
spcedwards214
8:24 PM
South Carolina
I need a timing cover for my 66 charger with the timing marks on the passenger side please PM if you have one you'd be willing to sell. I have the one that was on it with the timing indicator missing and one with the marks on the drivers side but not the right one I need. Thanks
You could also get a new balancer from Power Bond (PB1004N), and the timing mark will be on the correct side to match your current cover. The only thing you will have to do is to elongate one pulley bolt as the late balancer has an offset hole, and the early was symmetrical.
Sounds like you need the timing indicator that's missing. If so, drop me a PM. I should have an extra.
yes it is and yes I do need the timing indicator. I believe I found the correct timing cover out of luck on ebay but I guess well see. Thanks for the help in advance.
