need a part number
The number in use currently for that application is 3431459, the reproductions are not an exact copy of the original cable but is the only thing that comes close. Length needed is around 71”.
Glad I could help. When I got my cable I could not find the correct one. So I used the one that had the plastic bracket with the screw hole. I carefully cut the plastic bracket off the cable and it works perfect. Those cables bend easly. Don't force it to open the valve. You may have to play with the cable to adj it. Get a few of the clips that the cable sits in at the back of the heat AC controller and water valve. Just so you have extra incase you break one. Ask me how I know
I think I broke the cable because the water valve itself is hard to move. I might have to take it apart, if I can, and oil it up. I've just operated the valve by hand the last few years but that, of course means stopping the car and popping the hood.
