Dibbons
- 2:42 PM
- Nov 29, 2014
- La Paz, B.C.S., Mexico
Well, have a probem with side window regulator slides. Put all the window mechanism back in the driver's door (except for the glass) and while testing the crank, I find the rear horizontal regulator slide wants to siide clear off the back of the track (when the window is about half down, I'm guessing). I don't see any other way of putting things back together (no, I don't have any fotos, diagrams, or drawings, and the FSM is not very enlightening).
I do see the rear of the track seems to be missing about an inch of its length, but it is is the same for the passenger side track, so I assume that is a factory stamping. Thank you for any and all help in this matter.
Pictures that follow in order are:
#! The plastic window regulater slide where the window would be about closed (up postition)
#2 The plastic window regulator slide about halfway out of the track and ready to fall out where the window would be about half closed/open. If I continue to lower the window frame it will fall out.
#3 The rear end of the horizontal slide (out of car foto)
#4 The front end of the horizontal slide (out of car foto)
#5 Picture of crank handle fastened to door
#6 and #7 views from the top of the vertical tracks where they are bolted at the window opening in top of door
