WTB Need exterior trim for 1965 Satellite
Jake'sPerformance
1:35 AM
Texas
Looking for the 1/4 panel louvers.
Front fender Satellite script emblems.
Roof rail trim.
Passengers door trim that goes over the top of the door skin.
I also need whatever holds the inner door roof rail trim. The trim has one hole for two in the rail.
Almost finished.
Here's a pair of fender scripts. Both are presentable yet. Some pins are missing but enough left to mount and secure them. One needs the black paint touched up more than the other one does. I wanted to mention there is a very slight difference in appearance between the two of them and one was mounted with barrel clips while the other with stamped trim nuts. I assume there were some differences in supplier or design and possibly at a different plant, during the year's production run. I've seen previously Satellite badges mounted both ways.
$28.00 each or $50 for the pair, plus shipping from 55031. I take paypal. See more postings to come with some other stuff you're looking for.
Here are both sides of the drip rail trim. Both are straight yet and would clean up well. One includes the windshield transition piece. I don't find that part for the other side. Mounting clips are shot. I would separate the pieces for easier/safer shipping. $75 for the pair plus shipping from 55031. I take paypal.
Here is the formed piece that goes at the top of the door. This is a pair. Both are straight and would clean up well. Your choice $25.00 ea plus shipping from 55031. I don't have the narrow trim piece that follows the edge of these. I take paypal. Please let me know either way if you're interested in any of this stuff. Thanks
The interior brackets you're looking for are a stamped upside down U shaped piece. Each leg of the U screws to the inside of the roof panel and the opposite end of the U has one hole in the center which the trim attaches to. I sold the last of those I had last summer. A Belvedere hardtop would use the same bracket, as would a Coronet hardtop. 64 is the same to the best of my experience.
I'll take all the trim pieces.
Get me a total with shipping and a Paypal address.
Thanks!
If you want both pieces of door trim it's $175 plus a guess (you hadn't provided a ZIP) at $25 for shipping. So $200 total. If you only want one door piece deduct $25.00 from the total.
Paypal address is coming to you via PM.
Do you have the interior chrome trim piece for passenger upper side trims out the headliner.
I believe this is what you're looking for. This one still shines but like the vast majority of them, has light to moderate pitting and a couple spots worse. Two small dings on one edge. Chrome is hard to photograph. Hope this gives you an idea of how it looks. I'd call it good driver quality. $20 plus shipping if you wanted it.
View attachment 919946 View attachment 919947 View attachment 919948 View attachment 919949
I'll will look a the piece I need to be sure it's the same. Thanks for the response.
