pistol_grip_polara
ok, I know I am not the first with this problem, but everyone's motor is different. I have done a lot of reading and think I have it narrowed down...
I have a 64 polara 2-door, with a 73 360 and a 64 4-speed. brand new mopar 360 11in flywheel with new clutch set up. The rearend is a 68 b-body 8 3/4 with 3:23 sure grip, running 245/60/15 all around. running headers with 2 1/2 collectors with 2 1/2 pipes with flowmasters and 2.5 into 3in tips
I am going to be finishing up my motor but need to order my cam. I got it already punched .030 over, but someone left some water set in the cylinders so it is now .040 over, brand new sealed power pisonts. (part number is at home) i do know they have a slight dome and have valve reliefs (not the flat tops). I will be running and oil windage tray, as well as a high volume pump. The heads I have are a set of 71 340 x heads, with 2.02 intake valves, freshly redone with new guides, 3 anlge valve job and very mild port work, (mainly just some cleaning persay). Running a set of early 273 adjustable rockers, (waiting to order proper pushrods depending on cam) The shop that has my motor, said he can deck the block.
My question becomes, if i deck the block and the heads are milled .010, what is that gonna do to my compression? planned on running the fel-pro gaskets but have read that the mopar brand ones actually have a more correct bore and a better crush thickness..
with the research I have down, i believe the best cam for my build would be the
P4120233AE: .508/.508 lift 292/292 duration 248/248 duration @ .050 centerline of 108 2200-6500 rpm
I have heard that cam is a dog without at least 3:55's but with my motor and a 4-speed would i be ok?
or would the
P4120231AE: .484/.484 lift 284/284 duration 241/241 duration @ .050 centerline of 108 2800-6200 rpm
I think im narrowed down to those to options, leaning more towards the .508 lift ..
any help would be appreciated. I hate to buy it and not like it.
or would the
