NEED LOWER DASH PAD RESTORATION HELP
dombee
2:11 AM
Stafford, VA
Trying to restore the lower dash pad on my 68 GTX but here are a few cracks that that I cannot make go away with the fillers and primers that I used. Any ideas on what might work or a good 4 way stretch vinyl to recover the entire lower dash pad?
Tks, Dom
I have a nice used one if that interest you ....send me a private message
Tks, Dom
I have a nice driver quality one if your interested and can provide pictures
Tks, Dom
I used a soldering iron with a wide tip and using the tip laterally to the line of the crack used the iron to weld the plastic together, using the plastic from zip ties as a filler material. Once you have a bit of stability in the part, you'll be able to prime and sand. Make sure you do this in a ventilated area though!
