Need pics: Carter 4401s Vaccuum Brake + Choke Thermostat
norcal_mike
11:22 PM
northern california
I just picked up a H-code 68 Charger with 383 4BBL automatic. There seems to be some parts missing on the Carter 4401s on the choke side.
There is a Choke thermostat which goes inside the intake manifold, however there was no linkage to the Vacuum Brake, according to some diagrams, there should be a rod which attached the Vacuum brake to the linkage, but I'm not clear where the thermostat should connect to.
It would be great if someone can post a pic of a stock setup for that side. Thanks in advance.
