It's that time of year, and I need to get busy making this Halloween's Big Build. This year it's Pumpkinhead... this guy:
We got most all of the static build issues worked out, but I'm getting kinda tired of totally static figures and want to make Pumpkinhead wag his tail. So, how does one go about making about a 10-foot long tail wag?
The best idea we've gotten so far, and you're going to have to use some mental powers here, is to use Solo cups and ping pong balls. If you think of holding a tall stack of Solo cups, if you tilt them they will lean. Now think of putting a ping pong ball between each cup to act as a bearing, and the stack of cups will lean a lot. Put a small hole through each ball and in the end of each cup, and run a string through each ball and cup from front to back, and we should have an easily bendable tail-looking appendage.
The next step is to put four small holes spaced around the base of each cup. at 12, 3, 6, and 9 o'clock, and run four strings from front to back through those holes. That way if I pull the 9:00 string, the tail will pull to the left, 3:00 will pull to the right, 12:00 will pull the tail up and 6:00 will pull it down. That part is pretty simple. What isn't simple is how to pull the strings.
So here's the dilemma... what can we make that will put tension on four strings, one at a time, and then release pressure as another line gets pulled tight, and will fit into the body of a mannequin? Think of essentially a four-cylinder engine's crankshaft in operation.
