Need some help getting Fender Tag replaced
ArtistStan
3:34 PM
Fort Worth, TX
I have a 69 green roadrunner with about 3/4 of the build sheet. I went to this Backeast company in Colorado to get a fender tag. They told me that the A Plant (lynch road) tags are completely different and they require Gate Sequence, Line Sequence, and Base Sequence to produce the tag and those numbers do not come off the build sheet.
Also the build sheet is partially destroyed so I don't have a build date. Any ideas on that?
They recommended that I ask around and see if someone will have an idea of what those numbers could be for my car.
Where would I start to get these sequence numbers? Stan
ps And if you know of anyone else who can do tags for me and might have that info, please advise.
The info for your car is impossible to know. It was unique to that particular vehicle and only listed on the tag. No one will have it.
Remade tags are very controversial. Many people have spent good money only to buy a really bad part or to buy a car that came with a bad tag. Check for threads on this board for examples.
"Guessing" at the data could expose the tag as a bad fake tag.
Having a bad tag could raise questions about the car you may not want asked.
Sometimes it is better to have what you have, no tag and at least part of a broadcast sheet, than to compound a problem and have a bad tag made for the car.
