Need some help with wiring my 68 roadrunner
bhood
New Member
4:38 PM
Louisiana
First off would like to thank you for having me on the site. I am currently in the process of restoring a 68 roadrunner. It has a 440 with a 4 speed and is coming out beautifully. Ok now to pick yall brains for a min. I bought a complete wire harness from year 0ne that is set up for electronic ignition. I have the distributor and orange module that bolts to fire wall, but not 100% sure what else I am missing. I bought the car tore down and cant really find any pictures of the wire routing or electrical componts. If yall have any pictures of your rides wiring system, I would be grateful to take a look.
I think that harness needs the 70 and newer 2 field alternator, electronic voltage regulator, and 4 prong ballast resistor.
welcome to FBBO
maybe post the question in the general discussion section
or the electrical & Ignition section you will get more responses that way
this is the welcome wagon it's for intros & getting to know each other,
not really intended as a Q&A or tech forum section
good luck maybe this will also help
  • Chrysler Electronic Ignition Wire Diagram 4 pin Ballast & Electronic Volt. Regulator.jpg
Welcome aboard FBBO bhood. :hello2:
Budnicks has given you some good advice, and a helpful drawing. Questions are sometimes answered faster in the appropriate section - Technical, electrical etc. Good luck with your rebuild. :headbang:
Some pictures of your car and progress will go a long way to getting more help. :icon_winkle:
I've always used the 2 prong with the electronic conversion.[many times]
