Daly
I'm putting a set of Sidewinder heads on the 440 in my 69 Coronet. The 440 is a 74 and I'm leaving the bottom end alone. The engine runs good, but one of the heads is cracked, which is why I'm putting the Sidewinders on.
Where I need the help is while I'm putting the heads on I thought about putting in a mild cam and dumping the heavy intake, but I'm not sure what would work the best. Comp Cams? Lunati? Edelbrock? Crower? Single plane intake? Dual plane?
Basically wondering if anyone else has done just the top end on a 74+ 440 and what did you find was a good combo...
Also for the initial swap I'm leaving the stock exhaust manifolds, but I will be getting headers do the line. For now I just want the car back on the road...
