New engine start up on test stand - wiring question
DWinTX
1:36 PM
North Texas
Today I hope to start up my just built poly stroker for the first time. It's on a test stand (pics below, because everyone like pics
) I'm down to the last couple of things, and one is the wiring. About all I know about electricity is that it shocks me when I'm stupid. Apparently, I'm stupid a lot.
So I drew up this chart with the way I think it's supposed to be wired. Can someone who knows what they're doing tell me if this is right? Obviously I want it to start quickly for cam break in.
Couple of notes:
  • I'm using a FireCore Ready to Run distributor. My understanding is that this does away with the ECU and ballast resistor. The instructions indicate red to coil positive, orange to coil negative and black to engine ground.
  • The new alternator has the 4 connections shown, but one FLD and the GRD terminals are just threaded holes, no lugs are attached. I'm assuming it grounds through the mount and I only need one FLD lug. Some online diagrams show a FLD1 and FLD2. These are both just marked FLD.
Thanks for any help you can give me. This is my first build and it's been interesting to say the least. Not sure a poly stroker was the best choice for my first build, but I've learned a lot!
Can't help you with the electrical questions. ....but any details on the stroker build?
Cool engine!
Jeff
Hi Jeff,
These are the specs:
349 CI
Schneider solid flat tappet cam: http://schneidercams.com/264Fpolysolid.aspx
Chrysler Power Wind Tunnel manifold
stock poly heads
TTI long tube headers
Forged SIR press fit piston rods & ARP fasteners
Scat internally balanced 3.58” crank SCA-934010
Keith Black/Silvolite #1278 flat-top no valve relief piston/pin set 1.658”comp. ht.
Got everything but the headers and manifold from Gary Pavlovich, who is a poly stroker expert. He's done some really radical ones, up to 500hp, IIRC.
