glassman
What causes the new concrete floor to sweat. It is a pole barn construction that is 60 plus years old and the floor is 3 months old. I have never seen a floor sweat this bad. How do I stop it?
You can seal it now, if you use urethane Moisture cured sealer. it loves the floor sweat. But they should have put a moisture barrier under the slab.
This is a 2 year old thread that I started and again I have a new slab of concrete, 30x42. First slab was 40x42 with no plastic , but this new slab has the plastic between the gravel and the concrete. I will keep you informed on any sweating issues. So far, noneWhat causes the new concrete floor to sweat. It is a pole barn construction that is 60 plus years old and the floor is 3 months old. I have never seen a floor sweat this bad. How do I stop it?
Mine has plastic and still sweats some days in the summer. I used to use a dehumidfier but it got pretty warm on hot days. Now I installed old window style AC unit. Works excellent even cooling 960 sq ft.What causes the new concrete floor to sweat. It is a pole barn construction that is 60 plus years old and the floor is 3 months old. I have never seen a floor sweat this bad. How do I stop it?
That and all the other things inside including bare (and now rusty) metal.If it's been cold inside inside the garage for a long period of time and you throw open the doors on a warm day, the floor is going to sweat no matter if there's a moisture barrier or not.
