Here's an update on my progress
This was the first time I have ever installed a drivetrain like this. I bolted the engine, trans, and K-frame together and slid it under the car. It worked very well - and I'd suggest doing it like this again in the future. No issues with header clearance or anything!
Oh, and must add that I did this all by myself.
![IMG_2417[1].jpg IMG_2417[1].jpg](https://www.forbbodiesonly.com/moparforum/data/attachments/184/184200-fd8df6a64c594367336a4afb21fbd95a.jpg?hash=_Y32pkxZQ2)
Lowering the engine onto the K-frame
![IMG_2424[1].jpg IMG_2424[1].jpg](https://www.forbbodiesonly.com/moparforum/data/attachments/184/184201-6aed4d5815ee74b4cf314ccfdbefb56b.jpg?hash=au1NWBXudL)
The whole drivetrain bolted together.
![IMG_2432[1].jpg IMG_2432[1].jpg](https://www.forbbodiesonly.com/moparforum/data/attachments/184/184203-5bbc0447489b23a75ae800d62be8a96d.jpg?hash=W7wER0ibI6)
I used my engine hoist to lift the car up using a tow strap.
![IMG_2442[1].jpg IMG_2442[1].jpg](https://www.forbbodiesonly.com/moparforum/data/attachments/184/184204-2adbd36ebededd9abb1a563e994e76a8.jpg?hash=KtvTbr7e3Z)
If you do this, be sure to block the rear of the car up under the differential so the car can pivot on the stands.
![IMG_2448[1].jpg IMG_2448[1].jpg](https://www.forbbodiesonly.com/moparforum/data/attachments/184/184205-329b3d6deb162940144e185c5445bd18.jpg?hash=Mps9besWKU)
Lowered the car right over the entire drivetrain with no clearance issues.
![IMG_2451[1].jpg IMG_2451[1].jpg](https://www.forbbodiesonly.com/moparforum/data/attachments/184/184206-da3457ba715315a1d336c7fa720c1622.jpg?hash=2jRXunFTFa)
All the way down.
![IMG_2454[1].jpg IMG_2454[1].jpg](https://www.forbbodiesonly.com/moparforum/data/attachments/184/184207-c5f9ae9e7ae9bdade9543097e2186d3a.jpg?hash=xfmunnrpva)
It's installed!! Just a few wires to connect, fuel lines, a radiator and it's ready to run.
I was so close to getting the whole thing running... just a little impatient... and forgot to hook up the starter wires. When I turned on the battery, the main power wire grounded on the starter causing the positive wire to burn instantly. I had it on for maybe 3 seconds... oops
This was taken a moment after I shut the battery power off!! yikes.
Here's the damage. Though it looks bad, it was only the positive wire running down to the starter.
