Z-Bee
So Ive been a Mopar lover since my first car, '73 Duster. I now have a '68 coronet that I am going to put a 440 in. Bought the 440 off craigslist and the owner only new that it was rebuilt by a high school shop class a few years back and has never been fired up. I wanted to do as much research on the engine before I put it in and fire it up. Block stamp is 2536430-3 which makes it a 1966-72 440. The heads are 28439906 which makes them 906 heads. The crank is forged steel because of the wide parting lines. Comp cams roller race timing set.
So what I need help with is I can't I.D. the camshaft and I don't want to pull it. Took the timing chain cover off and no numbers on the front of the cam. I also need to know about the pistons and possibly the connecting rods. How do I I.D. them? The pistons all have 030 in blue on the side visible with the oil pan off. Does that mean the block has been bored 0.30? What size carb will I need? I will be running hooker ceramic coated headers and a 727 tanny. Right now it has a stock 4 barrel intake but I would like to upgrade to a dual plane.
Any suggestions will be greatly appreciated. I have found a ton of info on this site so thank you all.
