New to the Mopar world. Need help with 2 questions
Thanks for the encouraging comments guys,
Moparmarks, thanks for decoding.
I had a feeling the engine color was wrong and I don't really like the vibrant blue. From my knowledge and watching my uncle build his 71 Challenger R/T the engine is ORANGE with chrome blocks/headers??? Is that right? Engine will probably be the last thing I do due to cost.
VIN and FENDER TAG match. Is it possible to take fender tag and vin and move to another car? Answer is probably yes but still have to ask. The original owner told me the car is not an R/T and is a 383. If fender tag says it's a 440hp R/T I just scored a big deal no? Here goes another question. I thought R/T's had the flare vents coming out of the doors? Mine has the two indent grooves.. Totaly lost now and worried someone switched tag's on this resto.
'68-'70 Chargers all had the two indents on the doors. The '70 R/Ts had the covers you speak of. The VIN is also stamped on the rad support...driver's side IIRC, and under the trunk weatherstrip also on the drivers side.
I think things are matching up...
Ok, so I checked inside of the engine bay, just in front of the RAD. I found this - It was sanded and it shows the original color, yellow.
From the picture you can see it says G9 136288 but on the vin it shows a bunch of #'s ...9G 136288. The G9 and 9G are reversed?
I can't find the number in the trunk under the weather stripping b/c it's glued and I am affraid to rip the stripping as it can be anywhere under there.
welcome tendy! to check the trunk rail numbers you will have to peel a little bit of the weatherstripping back, but its really no biggie...IIRC your charger's numbers and my GTX's numbers are in the same place.
check it out...
vin decode
Here ya go..
XS29:
Dodge Charger
Special, R/T
2 Door Sports Hardtop
L9G: 440 375HP 1-4BBL 8 CYL
1969
St. Louis, MO, USA
196268: Sequence number
E56: Unknown
D32: Heavy Duty Automatic Transmission
Y2: Yellow Exterior Color
Y2: Trim - Unknown, Vinyl Bench Seat, Unknown Color
C6X: Unknown Int. Door Frames
X9: Build Date: 9
930: Order number
EG4: Unknown Top Color
C51: Bench Seat-Split 50/50
C16: Console w/Woodgrain Panel
C55: Bucket Seats
C33: Unknown
U25: Unknown
L31: Hood/Fender Mounted Turn Signals
L21: Unknown
M25: Wide sill moldings
M31: Belt Moldings
M91: Luggage Rack
R11: Radio Solid State AM (2 Watts)
V1X: Unknown
V8X: Tranverse Stripes, Black
ERD: Unknown
nice black with red stripe hell yes :headbang:
  1. XS29:
    Dodge Charger
    Special, R/T
    1969
    St. Louis, MO, USA
    E56: 440HP
    Y2:
    C6X: Charger vinyl bucket black interior
    X9: black door frame
    930: SPD​
    085916 order number
    G4: ?
    B51: Power brakes
    C16: Console
    C55: Bucket Seats
    G33 left o/S mirror
    U25: 8.25x15 bsw tires
    L21: Trunk lamp
    M31: Belt Moldings
    M91: Luggage Rack
    V1X: Black Vinyl top full
    END: end of shift
    Could you check the G4 code?​
Moparmarks,
Are you asking me to check the G4 code?
Lot's of things in this decode list to consider.
I found the trunk code as well but I cannot read it. It's pretty beat up. It looks as if there are two 8's in it which would match other fender tag, vin, and IIRC # but with the trim glue and newer paint it's near impossible to tell what it really says.
Welcome and congratulations! I too am a newbee from the cold dark north...west....Alaska. I love the pictures and know you are proud of your new girl, you should be. I hope you get as much help from these professors at Mopar University as I have and I will be willing to help anyone as I further my own education. Keep those pics coming, they fuel ALL of our fires! Mocajava
