Nacho-RT74
- 12:51 PM
- Oct 8, 2012
- Valencia, España
When brake lights fail you could try to replace the canceling cam and try to save the original switch. This assembly consist on a points and springs system that spreads the signal around accordingly to its position. These can get worn or weak.
Canceling cams are available and not expensive. It worths the try. Sure the rest of assembly (not just the cam side) gets worn too, but at least enlarges its operational life a bit more.
