Dibbons
- 1:56 AM
- Nov 29, 2014
- La Paz, B.C.S., Mexico
I dedicate this thread to the unmentionable problem of window and panel alignment (door, fender, trunk, hood). My vehicle is a '72 Satellite Sebring Plus. After re-painting, "restoring" the door hinges at home, and installing all body parts things are not all lined up correctly. The saving grace in all of this is the passenger door opens and closes like new. The trunk alignment is close enough that I won't be messing with it.
The drivers door (and window), front fenders, and hood need attention.
First thing I need to tackle on the passenger door (which fits fine already) is push back the pin in the lower hinge that holds the roller for the spring (it is working its way out the bottom: see fotos). Of course, it will not tap back in on its own. I dread removing the lower hinge on the perfect operating door, but what choice do I have but tape up the edges, mark the hinge, and yank it off? Might do a tack weld or tack weld a washer so it can't repeat this "falling out."
I know, the hinges are a funky color, please keep comments to yourself.
