Nylon window rivets and spacers
TRAMO
7:15 PM
LEBANON TN
Feedback: +1 / =0 / -0
View attachment 140072I bought a 70rr that was already disassembly and i am putting the glass back in and not sure what all i need.i know i need the nylon rivets thats at the bottom of each door glass but is there also some nylon bushings or spacers in each side glass that i also need? where can they be bought at resonable prices? and can you buy a door glass kit? these rivets/bushings i know the one on left goes in the lift bracket i assume the one on the right goes in the hole towards the back end of the window but what ourpose does it serve? and what is it called. thanx
eBay, they are cheap!
Are you talking about the plastic rivet things that hold the side glass roller bracket to the side glass? Those can be had at any restoration company just check out a few of the sponsors on this site. As far as spacers between the glass and bracket yes there should be some glass setting tape that you can put in between since metal sitting against glass is never a good thing. You can get that stuff at most windowshield companies.
