shovelluv
This is regarding my oil and temp gauge.... I have a very well grounded engine to chassis. It is grounded heavy to the firewall, battery, core support and fender. Heres my problem with the engine running, yes, the sender is for a gauge part s330. If I take my meter, one lead to the sender the other to chassis ground i get a closed circuit to ground which pegs my gauge. NOW, If i put my ground lead on my meter to the negative on the battery cable on the block it reads 10ohms, if i put my meter ground lead on the oil sending can direct I get 22ohms which is what I want and would put my needle on my gauge at about 1/2 way. I have the same problem with my temp sending circuit. I have not re-installed my gauge cluster yet because I just restored them, i am testing to see what the ohms are going to be with it running at normal temp.
