PRHeads
- 12:49 AM
- Aug 31, 2018
- So. Burlington Vt
My experience with the stuck bypass valve was the result of a very small metal shaving getting wedged between the pump body and the valve……. Resulting in it being stuck in the fully closed position.
This was a 340 with a Melling M72HV pump.
The result of that was a hot idle oil pressure of about 120psi.
It instantly pegged the 100psi mechanical gage, and the needle never moved.
I ended up attaching a 300psi gage to the engine to see what the pressure actually was.
(You won’t believe how high it would get when you revved it up)
Pulled the pan & pump, pulled the pump apart, found the issue, put it back together……… no more 120psi hot oil pressure.
I don’t recall what that was(30+ years ago), but I don’t remember it being strangely high.
So, my experience is that with the bypass valve completely shut, the hot idle oil pressure was about 80psi higher than when the bypass valve is functioning.
My takeaway from that is the bypass valve is “bypassing” some amount of oil anytime the engine is running.
So, a stiffer bypass spring will keep more of the bypass hole closed off at any given rpm.
Less bypass area = more psi
