Old odd tune up tools
Mike Szadaj
8:06 PM
St. Clair Shores, Mi
I recently picked up these two old tuneup tools. One claims you can set the distributor points without a dwell meter or feeler gauges. It wouldn’t work on Mopar distributors, only the type that you can adjust the points while the engine is running. After reading the instructions, it doesn’t sound much better than adjusting the points by ear.
I haven’t figured the second one out. The bottom red part turns, and as it turns it moves up and down. As it moves up it first covers up the word polarity, then the word output, then the word plugs. As far as I can figure, that determines which ignition electrical item it is then set to check. There is what looks to be a neon bulb in the top of the blue cone. If anyone knows how it works, please let me know
The bottom tool will show how much the coil can put out. Its just like a spark checking tool. As you adjust the gap wider the spark will eventually stop. Most newer ones have a graduation gauge in kilo volts.
