EngineerDoug
Hello all,
I have finished restoring the front end of my '68 Coronet and will soon be moving to the rear of the car, where most of the rust damage is. I have the body shell on a dolly, and have replaced the torsion bar crossmember, front pans, and installed subframe connectors + torqueboxes.
The quarters, trunk floors, and rear crossmembers will be replaced, along with the tail ends of the rear frame rails. I am thinking through the order in which I should remove and then replace these major structural pieces. The rear frame rails are already supported by verticals welded to the dolly. Let me run this past you folks for your consideration:
1) Cut out old trunk floor + extensions.
2) Cut out rear crossmember.
3) Cut out frame rail ends & replace.
4) Cut out quarter panels.
5) Replace trunk floor + extensions and secure with temporary screws.
6) Replace rear crossmember and secure with temporary screws.
7) Replace quarter panels - clamp in place.
8) Once everything is fitted, weld it up.
My thought is that the rear frame rails supply much of the support for the rear of the car, so keeping them supported will provide a base upon which to build. Getting the trunk pans fitted and in place will be a lot easier before the quarters go on, so they will be fitted next. The quarters will be last, and everything that precedes them can be adjusted as needed before final welding.
Does this chain of events make sense? I know that the back end of this thing is essentially a big puzzle, and the major parts support each other. Note that I will be replacing complete quarters from the sail panel on down.
Thanks!
Thanks!
