Macdon221
Good Day All,
Original Carter Carb. 440. Original Carter Choke. Spring works fine when heated. Carb is set up meticulously as per the FSM for all settings, Carb works awesome all phases of drive, power and idle. No hesitation or bogs.
When warm...the curb idle screw has been set to the proper rpm (1700) when on the second cam as per FSM. On the first cam it is about 1400 rpm.
My question....
When the car is cold, and the choke rod is pushing the choke closed....should the choke cam rotated by the choke rod so that the fast idle screw is setting on the second cam fully cold, or the third and highest cam? Then when the carb diaphragm energizes on start up and you blip the throttle it takes it immediately pulls it off from a super fast idle to the second cam at 1700rpm?
Hopefully this makes sense!
Macdon221
My question....
Macdon221
