Overheating issue
mopar951
11:15 AM
California
Hi everyone I’m having trouble with my 69 coronet it has a 318 and the trouble I’m having is it’s overheating on trips that are like 20-30 miles it has a new thermostat new upper and lower radiator hoses and new coolant I took the rad out a flushed it and nothing really came out it does have a newer rad cap I have a video of what it’s doing in the radiator with the cap off but it’s just swirling around it’s not flowing any insight I was thinking water pump?
To be sure the radiator is not the problem it needs to be rodded out by a radiator shop.
They take the tanks off and clean out the core properly.
When you say swirling around, is it not doing that at idle? Or just at throttle?
My "66" with the factory 361, was easily running hot.
I bought a radiator shroud and that fixed it.
Pull the radiator and have a radiator shop clean it out. Fan shroud is also a big help. Put a spring in that lower hose to prevent collapse. and get a FlowKooler water pump with hi flow 180 thermostat. .
