FOR SALE Parting 66-67 Coronet 500 and 500 vert
Factory dash to cowl bolts
13 shipped
Misc 66/67 factory hardware
glove box hinge screws
rear interior chrome screws
sun visor screws
weather channel hardware
throttle bracket
fender bracket and bolts
sill plate screws
arm rest screws
dash hardware
headliner teeth screws
Unfortunately I don't, but I will ask around.
More factory hardware
fender bolts and brackets
vert sun visor insert (plastic)
rocker molding clip
door badge mounting screws
air vent screws
hood latch release bolts and striker screws
suspension rubber #4394 696
black door jamb screws
trunk light activator switch
ebrake mounting hardware and clips
1/4 panel letter speed screws
factory horn mounting hardware
Original driver quality factory parts and hardware off a 66 Coronet 500 and 67 Coronet 500 vert
I no longer have grille surrounds, tail lights, trunk finish panels, letters, glass, bumpers or seats.
gas cap 13 shipped
alt gauge never installed 25 shipped
66 ac firewall grommet 8 shipped
following items are 15 each shipped
glovebox lock and screws 15 shipped
hood hing bolts, horn bolts, fender brackets lot, hood spring, chrome vert boot snaps, vent cable hold down, seat belt bolts, lock cylinder and clip, 1/4 panel letters and speed nuts, headliner bow clips
rearview mirror 45+S+HOriginal factory Coronet/b-body small parts and hardware lot
70 Charger hood release 22 shipped
coil and bracket 15 shipped
door jamb seals 20 shipped
sill extension 15 shipped
1/4 extension tail light trim 25 shipped
original gas filler tube clamps 12 shipped
air vent j hangers 13 shipped
66 ebrake light, lens and mount 12 shipped
67 reverse light mounting brackets, hardware and lens screws 25 shipped
67 hood letters, all pins intact 24 shipped
high beam switch 12 shipped
window roller 12 shipped
bumper bolts 15 shipped
67 turn signals, gaskets and pigtails 25 shipped
lock cylinder and clip 14 shipped
windshield clips 15 shipped
distributor hold down 14 shipped
66/67 Coronet door parts lot
door hinge set and factory bolts 85 shipped
door mounting plates set 18 shipped
striker w/ 3 bolts 18 shipped 2 others available not shown
door handles 22 each shipped
inside door handles 15 each shipped
door lock release 15 each shipped
door rod j hooks 8 each shipped
door lock rods long 15 each shipped
smaller rods 12 each shipped
door lock button and bezel 12 shipped
door locks with rods 26 each shipped
Original driver quality weatherstripping off 66 Coronet 2dr hardtop
25 +S+H
headliner bow set 35+S+H
e-brake assembly 20+S+H
tranny tube and stick 15+S+H
fender patch 15+S+H
center radiator support 15+S+H
left and right lug nuts 17+S+HOriginal driver quality weatherstripping off 66 Coronet 2dr hardtop
25 +S+H
fender patch 15+S+H
Original window parts off a 66 Coronet 2dr hardtop
regulators 43 each +S+H
door window tracks w/ brace 24each +S+H
1/4 window mount 16+S+H
1/4 window mount w guide 36+S+H
smaller guides and brackets 16 each shipped
ashtray housing 22 shipped
glove box hinges and hardware 22 shipped
66 Coronet 2 dr hardtop headliner teeth set
45+S+H
door lock rods 15+S+H
tail light buckets with gaskets and bulb sockets 30+S+H
fender cover, ebrake pad and insulation 17 each shipped
Original driver quality 66/67 Coronet dash parts
Under dash courtesy light 18+S+H
glove box light 18+S+H
glove box liner 18+S+H
glove box latch 14 shipped
nice grille center 45+S+H
antenna radio wire 18 +S+H
arm rest bases need rechrome, 10 each +S+H
tail light lens 26 shipped
headlight switch, bezel and knob 24 shipped
wiper switch, bezel and knob 24 shipped
67 440 tail light gasket 12 shipped
window cranks 26 shipped
66 blower motor 45 +S+H
66 reverse light harness 14 shipped
66 rear bumper spacers 24 shipped
66 throttle pivot 24 shipped
66 ac wire harness 45+S+H
66 steel bumper filler pans 28 shipped
66 metal driver side inner fender cover 14 shipped
metal chrysler ac tag 12 shipped
ebrake firewall grommet 12 shipped
66 engine compartment wire harness clip 12 shipped
66 Coronet c chrome 22 shipped
certicard holder 14 shipped
66 sway bar tabs 24 shipped
66 tail light bezel 24 shipped
45+S+H
Solid driver quality vert panels from a 67 Coronet
300 pickup only
Original radiator out of 67 Coronet
185 +S+H
Worked when removed
Parted 66 and 67 Coronet vert lot of small parts and hardware
Will sell vert pieces separately
Items are in NY
PM me here at site
photos available
Thanks for the ad
View attachment 372936 View attachment 372937 View attachment 372938 View attachment 372942 View attachment 372943 View attachment 372944 View attachment 372945 View attachment 372946 View attachment 372947 View attachment 372948
How much for the fender blinkers? And do you have the trim for the door panels ( front and rear)?
Thanks, shipped to 77385
buddy seat brackets gone
The part I need is pictured on page one under the radiator, if that is called the bezel. I think of it as the dash face, it goes from side to side and it's plastic. They butchered mine up to install some goofy radio !
Unfortunately another member got it last weekend. I will ask around though.
Joe do you have the front bumper braces for a 67 Coronet? Also do you still have the 67 500 grill?
Thanks
Mike,
I have 1 bracket and a nice grille. I will send you some photos. Thanks, J
No jack assembly parts.
Do you have driver side window parts like rollers and bracket that go into the wing windowtrack and interior. Sail panel light sockets with wiring 66 coronet
