DasFusca
- 11:43 PM
- Aug 15, 2011
- Southern New Jersey
I want these parts. I sent you a PM
alternator mount and bolts 30
fan pulley 30
water pump housing(original?) yes 50
crank pulley 40
Here is a list of more things I would like
Thermostat housing
dipstick tube
idler arm/pulley
throttle bellcrank bracket
throttle spring bracket
spark heat shield mounts between 6 and 8 passenger side
(all the wire harnesses) I Tried to name them
1)two wire harness mounts under head bolt to the rear of number 2 plug
2)the 2 four wire harnesses
3)the four wire harness drivers side
4)the two wire for the number 3 plug
and the bolts for all these parts
Thanks
fan pulley 30
crank pulley 40
Thermostat housing
dipstick tube
idler arm/pulley
Thanks
