parting out 62-74
Checking to see if you have a set of windshield wiper arms for a 71 Charger.
Mark,
You have any good usable rocker molding, L & R and front wheel opening molding L & R for a '73 Charger SE car........thanks
I'll check. Should have the rocker moldings.
I'll check. Should have some.
Looking for trans crossmember '62-65 for A-833.
Also - any chance you might have a vacuum switch for heat/vent control push buttons.
Looking for a wiper cowl, doors, front floor section and a passenger side quarter panel for a 65 belvedere two door post car.
I need the exterior, rear window sheet metal for my 64 Polara. Specifically the lower corners but would take the whole rear window frame if possible. My car is a 4 dr ht.
Thanks.
71 Charger ?
Steering column ? w/Wheel ??
Visors? preferably black ?
Seats, console?
lots of other misc parts?
Mike..
:icon_eek:
looking for a pass side rear quarter panel for a 73/74 rr/satellite
Looking for a pass. side rear quarter panel for a 73/74 roadrunner/satellite
Sorry just have some for auto tranny. Also 62 is different than 63-5. Thanks
Have a cowl and H/T doors right now. Thanks
Do you have a trunk floor and the left and right rear lower quarters for a 74 Charger? Thanks for looking.
Sorry I don't. Thanks
Thanks.
I should have a Dutchman filler panel and the inside package tray for a 64 sedan.
Seats, console?
Mike..
:icon_eek:
Have some column shift columns. No floor shift ones.
Which steering wheel?
Have some blue visors and bench seats in both high and low backs. No buckets or consoles right now.
Sorry don't have right now.
Thanks
Looking for a 69, Satellite/R. Runner/GTX pass. Ft. fender by chance
Sorry no 69 fenders right now.
Thanks
Are the floor pans the same in the 67 Sebring as a 67 Coronet? Do you have one?
And what about the grill frame?
Satellite and Coronet floors are the same. Just have some of the under rear seat pans right now.
Satellite and Coronet grills are different and I don't have either. Thanks
I'm trying to find the vinyl trim molding for my 71 Satellite. It has the full top. Do you have any of the molding?
Do you have pics of the 62 Belvedere? I am looking for the lower valance and signal lights. Also some of the trim but have been told it may be different based on Canadian and U.S.A. trim lines.
Looking for the piece of trim that goes across the hood of a 64 dodge, as well as a good trunk medallion.
Could you send me some pics of the Dutchman filler panel?
Mark, do you have rear window opening for a 65 b body post car I think 4 door is the same I need the flange area where the gasket would seat I can send you a picture if that helps.Thanks Pete.
Mark:
Wheel lip moldings for 71 RR?
