Parting out 67 coronet 440 4dr
I am interested in the windshield gasket if you can get it out in good shape.
No. Splash shields They are mounted in the front portion of the fenders behind the headlight bucket, it keeps roadspray and debris from gathering in the fender area.
Ron
I need a good front right brake line for standard 10" brakes. Also a small block engine wiring harness if you have one. Right now the brake line is the priority. Any help would be greatly appreciated. Thank you and Merry Christmas.
I need the right front brake line that runs across the firewall. Goes from the distribution valve below the brake master cylinder to the right side of the car. If the master cylinder hasn't got any water in it I could use all lines and distribution valve. I also need a small block under hood wiring harness.
Alex, there is a guy in the Indianapolis, IN area that has the front and back seats, i think blue. look on Craigs list Indy, INprice was very good.
striker plate for glove box also complete wiring harness engine compartment along with under dash
