SOLD Parting out my HT413
HT413
Semi Pro Bowler
3:42 AM
New Jersey
Feedback: 9 / 0 / 0
Well, with the 451 in the works, it's time to start parting out my good ol HT413. As you know, this is an RB motor that shares every part with a 440 except the pistons. The motor is still in the car and runs great. Runs strong, doesn't burn or consume oil. I will post photos of motor plus video of it running in a couple of days.
Prices do not include shipping.
906 heads, bolt on and go. no issues, run perfectly (engine does not consume oil or smoke in any way): (includes Mancini shafts and oem stamped rockers) $200
Forged crank along with fluidamper: $200.
LY rods, ready to run: $100.
Performer Rpm intake: $160. No stripped threads or machining.
Oil pump - $20
Chrome mid-sump 6qt oil pan (with baffle) and pickup: $40
Pro-comp electronic distributor (must be used with external electronic ignition box like the MSD 6AL, etc.) $25
B&M holeshot 10415 converter. Very tight converter, but does flash to about 2400. $100. (About $350 at summit) Perfect working order.
http://m.summitracing.com/parts/bmm-10415?seid=srese1&gclid=CO_x4PzauckCFU0XHwodPFYEcA
I'll be pulling the oem-type starter, timing set, cam, etc and will price them accordingly when I pull them so I can check id #'s.
Here's a video of it running...
Here's a nice video of the oil pressure gauge as it runs. You'll see it has excellent oil pressure: 60 at idle and rises to 80 as it revs.
As requested - here are some photos of the intake, etc. no stripped threads, mods or damage. image.jpgimage.jpgimage.jpg
ok fellas, intake, heads, fluidamper and converter are SOLD. I found the original damper for the crank and it will be included with the crank if you want it.
Everything else is still available.
Can't get through on PM. What's happening
Yeah my inbox got full too, saw you tried to message me, I got my heads and intake in.
