- 6:35 PM
- Apr 13, 2012
- Granite Bay CA
What?
Yeah....Over the years, I have stumbled upon and taken delivery of Mopar parts from a variety of people. I have some 15" stock steel wheels with bad tires so I dismounted the tires and went to replace the valve stems. I found that the hole in the wheel is almost the same size as the valve stem, something like 9/16" give or take. There is no way they would stay in place and hold air.
These wheels are nothing special except for being 15" size.
I have never seen a wheel that had a hole that big. At first I thought I bought the wrong size valve stems but now it just seems that some wheels used a different size.
I suspect that these wheels were from a 1968 or earlier car.
I saw THIS online....
Tubeless Rubber Snap-in Valves
If you drive a regular passenger vehicle, such as a standard-size car or a minivan; a light truck; or a light-duty trailer, then you will likely be interested in a tubeless rubber snap-in valve.
One key factor when considering valve type is maximum inflation pressure — this particular snap-in valve allows a maximum cold tire inflation of 65 pounds per square inch (PSI). You'll be able to find rubber snap-in valves to fit holes that are either 0.453" or 0.625" in diameter and in lengths that range from 0.88" to 2.5
Anyone have any info on what wheels had which size?
