SOLD Paxton NOVI 2200 S/C Kit
7:29 PM
Omaha, NE
Feedback: +0 / =0 / -0
I am selling a complete, new in the box Paxton Novi 2200 Supercharger tuner kit for a BB Mopar. These were introduced by Paxton a little over a year ago with the Novi 1500. I upgraded to the 2200 for more power. Everything is still in the bubble wrap and in the original box. Nothing has been mounted or bolted up. Only taken out to check inventory when I got it and to take pictures. Comes with the instruction manual, Novi 2200 head unit, all brackets for the head unit and to relocate the alternator, oil lines, 10 rib pulleys and belt, air filter and intake tube. Only thing needed is the carb hat, tube from head unit to carb and blow off valve. According to Paxton with the supplied pulleys it should make 6-8 PSI and with different pulleys and more boost, can produce up to 1000hp at the crank. I have changed plans for my build and no longer need this. I will post a few pictures but do have more of every part included that I can e-mail or text if you would like to see them. The kit is advertised for use with a 440, but as per Paxton can be used with a low deck with modifications to several water pump bolt holes. Asking $3200/obo shipped. PM me with contact information and I can e-mail or text more pictures.
Thank you
Chris
Good luck with the sale, your price is VERY reasonable! If I wouldn't have went turbo a few months back I would have picked this up from you.
Do you have pictures of the brackets and pulleys?
image.jpgimage.jpgimage.jpgimage.jpgI will post some pics. I am however waiting to hear back on a possible sale. I will update if it sells or not.
