69clone
Hi, I have a couple questions for you all.
First I'm getting a driveshaft built so I am taking measurements on my 69' satellite 440/727 Dana 60.
I also am trying to figure out the pinion angle of the rear and trans. I was told to get the angles correct before measuring so that you can get the proper distance. From what I read you take the measurements using the driveshaft but being I don't have a driveshaft installed how do I go about doing this?
I can tell the rear end angles up slightly in the front while the tail shaft seems parallel with the ground.
Otherwise will the angle really effect the length? I imagine it's minimal if I have to adjust it a degree or two?
