65-440
- 3:55 PM
- Dec 2, 2009
- virginia beach, va
Ok, assembled my new truetrac and all new bearings yesterday and had to set up the gears all over again. First pattern was way to the inside of the ring gear. That was with a .034" shim. After a bunch of shims and patterns later, ended up with no pinion depth shim in order to get a good contact pattern on the drive side. Coast side moved but but the best. Has anyone ever came across no pinion depth shim needed ?
