pivot shafts
Chilsam
5:56 PM
ILL
I'm rebuilding the front suspension on my 70 Coronet R/T...which is the best method of installing shafts.....bushings into L.C.A then shaft or shaft into bushing then as a unit int the L.C.A ?...THANX!
Bushing goes on the shaft, then bushing is pressed in LCA. You will need a pretty good press and pipes to press on the bushing flange.
I've 20 ton press ...HARBOR FREIGHT from a 20% off super coupon! lol...THANX!
