DevEngNerd
The internet is highly confused and divided on this question. Please add your valuable input.
If I've read you're other posts correctly, you have an MSD box, coil, and distributor- correct? In that case, as the instructions will show, no ballast resistor.The internet is highly confused and divided on this question. Please add your valuable input.
The question is if YOU use a ballast resistor., surely you can answer that with certainty.Define "modern" The instructions that come with it will tell you what to use and how to power it up. Must be careful on the internet. This FBBO Site has smart folks who can help you through your problems.
We can't answer this poll with any certainty.
The question is if YOU use a ballast resistor.If I've read you're other posts correctly, you have an MSD box, coil, and distributor- correct? In that case, as the instructions will show, no ballast resistor.
As mentioned above, could not vote due to lack of specifics
I can say with certainty that if it was required with the exact "modern ignition" components that I'd have on hand- I would use it.The question is if YOU use a ballast resistor.
