For starters, you need a power steering pump setup, brackets, hoses, etc. You need a power steering box, and you need to get a power steering length center shaft. The p.s. box in longer than a manual box and the shaft is too long. I did a p.s. conversion on a cuda I used to own and it wasn't too hard as long as you have all the parts. You will need to remove the steering wheel from the column and you need a steering wheel puller and a plate compressor to do this.
