Prepping For Herbs Dye?
dodge68charger
12:00 AM
Washington
Any Tips on Prepping The Glove Box and Dash Pad Surfaces Before I Dye Them?
Going From Blue To Saddle.
Thanks
Basic cleaning, then wax & grease remover. Finally microfiber towel with alcohol.
Wax & Grease remover can be purchased at any automotive paint store. Any brand. That's the only item that you might not find at other locations other than a parts store that deals with some paint supplies.
I just use wax and grease remover. I've never used Herb's dye, only SEM, and its awesome.
Don't be cheap with the wax and grease remover !
Worst thing in the world is everything looks great then you have a fish eye /flaw !
I agree with wax and grease remover. Some paint stores sell a bug and tar remover that has naptha in it and it seems to work. If the part can be washed with soap and water, I recommend that. The last step before paint I use a tac cloth to remove lint and dust. I just dyed my console with Herbs paint and the color was spot on but I had a little problem small droplets spitting out of the can.
I just did my glovebox door and dash plastic. I used Spray 9 with a toothbrush and kept using it until the rags came back clean. Then used Windex, then alcohol. Overkill perhaps, but it turned out perfectly. I used parts from three different dashes in two different colours to make them all a different colour yet.
I used warm soapy water, Dawn, and scrubbed a couple time. With interior parts you just need to get any ‘shine’ of so it doesn’t fish eye. The Herbs dye is pretty awesome stuff. I like the glass cleaner step as well, I use the foaming aerosol stuff. Use light to medium coats and it’ll turn out great.
I had some white handles on my boat that turned dirty and black/moldy looking. They looked horrible. I scrubbed them with Tilex Mildew and mold remover and painted them with Herb's white paint and they look great. I spoke with Herb and he too also used it on his boat interior pieces and at the time he said 3 years and no issues..
True, but it's just a quick wipe. And some plastics aren't affected at all, like for instance the bottles that acetone is often packaged in. :)
The bottles are HDPE but most automotive plastic is ABS or PVC and they don't like acetone. A safer choice is wax and grease remover.
I'd be careful with the acetone, it doesn't get along well with many plastics!
Sure it does. You can glue them back together after making a slurry once melted!!
i want to refresh the seat backs on my 67 GTX with some Herbs paints, im not looking for a color change.... my question is after i clean then clean and clean some more im going to wipe down with wax and grease , do i need to use a plastic adhesion promoter? these seat backs are steel, covered in a textured vinyl ? thats what it looks like.... any help is appreciated... thanks Rich
I just cleaned and used Wax and Grease Remover. Then masked the chrome and sprayed. Although I didn't change color it is very durable. Also as Medium Copper steering wheels are impossible to find, I used the same Herbs Dye on it. It was previously black. No problems yet, approximately 8 months old now.
