- 3:24 PM
- Dec 4, 2009
- Pasadena, Texas
http://www.metalwebnews.com/howto/rust/rust.html
Little bit of a large read and don't feel shy about adding to it!
When iron or steel starts to rust, it will puff up and expose clean metal to the open air, allowing rust to continue to the depths of the metal. If your favorite possession is already rusting and you want to clean it or at least stop the rusting, you have a few alternatives.
There are a few products on the market which fall into the category of organic rust converters. These products contain acid to convert rust to black oxide and polymers which bond to rust. Instructions say to remove all loose rust, paint on the product, and let it dry. I've used one of these products and it did work. However, the resulting surface is black and rough. Also, the converted rust is not durable, so this may not be the right treatment for tools or stock. Some trade names for these products are: POR-15, Glean Tech Rust Killer, and RustX.
