My question is when I was priming the oil pump and the engine, some of the oil go in side piston chamber by spark plug hole. what should I do or it ll cause any problem? Thanks
If you had the valve covers off while priming the oil system and some dribbled over and ran down the outside then its not likely you have oil in the chamber. But if somehow you did get to much got in the chamber you could hydraulic that chamber. I think I would crank it a few times with the spark plugs out to just be sure.
