PS Pump
300
4:25 AM
Canada
Well I got my pully off the TRW P/S pump, Now how do I take pump out, it's a pressed on pully, got that off, There seems to be a 4 notched ring on there, but don't know beyond that, Any help would be great. Thanks
Remove the 1 or 2 bolts on the back, and take the reservoir off. You will then see a large snap ring. Remove that, and then tap the shaft to push the rear plug out. After that, everything else will fall out.
Found the snap ring on back by two mounting holes. Now to get it out, doesn't have the two eyelet holes like a conventional ring does ?
There is a small hole in the casting where you insert a small punch to push the ring in. After that, you fish it out with a screwdriver. Yes, it does require some dexterity, LOL...
Don't see a hole in casting, except on top near ring, these are a pain, maybe a big hammer coming done on this
