Q1a upper control arms
Max lobato
11:38 PM
ca
hi b body fam
I just purchased new q1a upper contol arms and struts. My question is on my stock control arms my ball joint swivels on the new ones its a solid shaft. Is there something i need to add? Or can in be pressed into the spindle as is. Also i want to upgrade the spindles for disc brakes..any suggestions?
I "think" you mean the balljoint screws into the old control arm. The balljoint has a very strange thread and yes, they actually screw into the new arms. They seem to cut their own groove as they're installed. Use a proper balljoint socket !!!
If you're not referring to what I just mentioned and are talking about the shaft itself, then I believe its just tight because its new. It will swivel with some force and that is normal.
Thanks !
Now that you mention it i did not give it a whole.lot of effort to move the shaft. Ill give it a shot once i get back home
Thanks again
