Quarter Panel Glass Removal
Nardo
9:31 PM
Antioch, CA
Can you provide with any guidance on how to remove all of it so I can replace the glass and and all the rollers? I tried to take it off as an assembly but learned quickly that it not the way to do it.
Thank you in advance
Regards
The best guide is a service manual available at mymopar.com
Thanks. Like an idiot, I already purchased a CD Rom with this manual. I did not know there is one available to download. I already went down the rabbit hole and removed all the bolts of the quarter panel without know that we are to raise the window half way. No I am trying to take it apart without putting a dent in the quarter.
Thanks. Do you know where I might find the spring nuts that mount the glass to the regulator? My mechanic used all-thread and the glass was too loose. Thanks again
The rear glass and regulators are probably the most problematic job that you can take on.
Who ever designed these should be .......should have a GOOD FIRM TALKING TO.
I bought a second car, just to get the setup right. Like most of the miserable tasks, I try to clear them out of my brain, but I remember that the glass fishes in from the outside.
