Question about horn wiring...
Red63440
7:42 AM
NY
I was running my engine harness today and realized that I have one plug for my horns.....was there a jumper to go to the other horn..I can't remember what was on there....If there was a jumper does anyone have a factory piece???
Yes there should be a jumper going from one horn to the other. The first should be a female spade connector with one wire coming in and one wire coming out leading to another female spade connector for the second horn. I have the factory horns from my Polara currently in my 66 Newport...I could easily cut the wiring for the horns off of the Chrysler if you wanted it. I will have to look tomorrow but I seem to remember the female spade connectors being the same on both the 63 dodge and the 66 chrysler.
I was thinking that there was a small wire that plugged into both horns and then the main power lead would plug in to them. I haven't cut or modified my harness which is why I am at a loss now.
I have the harness from a 63 Polara I parted out, you could re work your harness with it.
Thanks but I can make a short jumper, I just can't remember what the heck was on there before I took everything apart.
My 64 Fury has two green wires on the lower horn one of which goes to the upper horn.
depends on the horns.two wire horns use jumper(from horn to horn),single lead horns(grounding through the horn body)take a split power lead.
Ya, figured that...all I have is a green wire, no connector and no jumper.:eek:
Hey man I forgot to go out and take pictures before work this morning. Give me a few and I will run out and take some pictures while it still light out.
What I would like to find is enough of the main green lead which includes the original female connector with the jumper. I could open my harness up and splice the line in and then rewrap it.
Here are two pictures. the first being the main female spade connector with the input and output wire going to the second horn. The second picture is both female spade connectors...one having the input/output and the other having only the input from the primary connector.
Thats what I need......:headbang:
